oi birds.
whats a good immune system booster, other than just vit C?
im seriously starting to get sick again.
changed all my food to healthy crap.
going through 3 bottles 750ml of water a day.
fkn still starting to get cold again.
Well for starters make sure you are getting enough Vitamin C. Chewable tablets are good for this.
Sleep is very important, need 8-9 hours a night - any less and you do make yourself more susceptible to colds, as your immune system drops. Stress is also a big factor in it.
General hygiene will do more for you than your immune system. Wash hands before eating anything, don't stand/talk too close to people (people with colds love to socialise and give no f**ks about giving their shit to other people). Avoid touching your face after shaking hands (sounds stupid, but everyone does it).
And once you do have any sign of being sick, head to bed and load up on the water / vitamin C. It'll be gone in 48 hours.
http://www.heraldsun...x-1226456412440
stuck in this traffic this morning, they blocked ring road off and hume traffic was bumper to bumper
Sad shit that, that you can be minding your own business without a worry in the world and in the next 10 seconds you're dead through no actions of your own.
These are the thoughts that bikelinesaustralia put up with everytime we ride.
Current brake set up is F242/Rdrums right. Should me buy brakes from vtec that are F262/R239 that'll be $500. Or wait out for Type R F282/R262 that will be 5lug (means have to buy new wheels/tyres) and would cost $1k for the brakes alone.
I wont be tracking this thing as of yet, but it'll be nice to get rid of the drums. Do some deca's ect.
Leaning towards the F262/R239 4x100. Which I can go pick up right nao.
She was only 22. The truck driver should have been able to see over the traffic that it had either stopped or was travelling slow. Maybe not concentrating.
http://www.facebook.com/#!/Signature.Imaging
This the Jon that came on our "midnight bakery" cruise?
It surprises me that there isn't more deaths from trucks when you consider how often cars crash.
That's me.
Trucks are involved in about 20 per cent of fatalities. I see ex-bomber Merv Neagle was killed in one this morning in NSW.
That's me.
Ahhh welcome to the wasteland. Have to have another cruise soon when the weather is a bit more promising.
He was killed in the truck or by a truck?
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
