VII.9 :yes:
The VII is a bit unloved, as the body styling is plain when compared to the VI and VIII.
VII are cheap, why would you bother with a VI with flogged bushes and gearbox.
inb4 Richo buys one for Time Attack
According to Wiki:
R32 GTR - 1,430kg
R33 GTR - 1,550kg
R34 GTR - ?
Evo 6 - 1,260–1,360 kg
Evo 7 - 1,320–1,400 kg
Evo 8 - 1,320–1,410 kg
Evo 9 - 1,310–1,490 kg
Add 18" wheels/tyres, exhausts, bigger brakes (a common GTR upgrade where EVO doesn't) and so on and it can certainly get higher :)
I suspect a R33 is heavier than 1550 to start off with. My GTS-R was 1400kg without me in it as i weighed it, and the GTR feels a LOT heavier than 150kg more. I remember driving Snowys R34 years back and it felt like at least 250-300kgs packed into it as it was similar from driving a EVO6 to a R33 GTR feels about the same in terms of difference.
Plus half the time the figures are not 100% accurate from a manufacturer as they dont say if its kerb weight (full fluids) or not.
A 6 and a 33R similar weight? No chance .. ive driven both and the 6 feels much lighter, even though the 33 R ha more power.
Maybe a 7 might be nearing the weight of a 33r but I doubt it
Seems about right
I can confirm this for you, my GTR is a 1999 R34, i have coilovers and a exhaust on it with a set of NUR spec NTo3+M rims, and i had to weigh it for blue slip, it came it at 1640KG with a 3/4 tank of fuel.
With next to no fuel,...
Eastern Ck weigh station (if accurate)...
V-Spec N1 = 1528Kg
Tony, nah cos no mention of N1 turbs, PFC and I don't see Brembos from the pics.
Different coilovers and 30,000-ish km has 'disappeared' there's paint fade on the roof that I don't recall seeing when its in my ownership.
Lol Aaron what you smoking brah
Don't think anyone said the 6 and the 33R were similar weight :P
what it sounds like? lol i've read it three times and sounds the same.. maybe my mind is f**ked today
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
