they probably saw the film together or something iuno, girls can watch batman too :P
Yeah they can, but to remember that line I darno
My gf has seen it but I bet she'd had nfi where that line was from If i said it lol
It could be a boyfriend?
Grants on the money here :P
That's gay
Gotta look into another angle.
Try telling this quote to your missus and see if she recognise it from Batman movie and report back.
another angle?
it says jake up the top, grey would be jake.
green is the 1st person (girl).
if grey is jake, then the person sending (Green) is a girl.
if the green is a guy, then (the grey) jake is also a guy, it will mean gay?
theres no other way to look at it.
maybe leigh got broken up with by a "Jake" poor leigh.
caption was "classy way my boyfriend left me"
pretty sure the worst I did was at maccas once, before we even started eating she picked up her tray and walked off lol I probably should of waited a few minutes aye
*sigh*
jake is the person green is sending the message to right?
so that would make jake = Grey
now if green wasn't a girl that would = Gay.
Jake is not a girls name.
hint: Green says delivered.
another angle?
Hrmm
If it says Jake at the top, means that Jake is the person receiving the text.
Only a guy would send a text like that
Meaning that they are homos
Whhhhatttt
Confusion LOL
Jake is the guy receiving the text message.
If you look on you phone any message that you send will have the name of the person receiving the text message at the top.
lol yes.
jake is the guy receiving the green message.
the green message says delivered, which would mean thats the message being sent to the name at the top.
so messages being received on that phone would be from Jake, and received messages are grey.
which means if green was guy - they would be homo
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
