Quick question guys.
On my licence, Licence Expiry: 03/09/2012
So does that mean it expires at the end of the 3rd or starting the 3rd it's expired?
Your licence expires on the 3rd at 11:59pm. So you need the new licence ready to use on the 4th.
I thought a registered vehicle can be defected anywhere, wheres the private property aspect come into it?
nope. against da law mang.
they arent able to defect on private property, in yo garage, on yo driveway, in a shopping centre(unless they pulled you over from driving on a pubic road)
Has that been confirmed by anyone or forum myth?
Not saying your wrong just surprised cos really if it's registered the intent is to use it on the road and people get defects at McDonald's an car parks etc
Yeh confirmed I don't know where it would be written though, its why they couldn't defect any of the cars in the carpark at JDMST.. As its a privately owned business and privately owned building. A lot of those defects if you read it carefully the cop has written the street name and not "oakleigh McDonald's" for example. If you were to take a photo of the defect being written or a video(even better) and fight the defect and fine you would win. Jono w.( is a mate of mine) who is a hwy patrol officer and has confirmed this for me
The only catch is if you were to get pulled over on the highway and no where else to park but maccas.. If u were to fight it, then they have video of you driving
i've heard that shopping center carparks are deemed "highways" and thus you can be defected in them. happened to a whole bunch of cars at some meet in a Chaddy carpark. cops were notified before hand, rocked up and blocked exits and handed out defects to show cars (inc some that had been trailered in)
have also seen it happen at monash uni carparks when we used to do kebab meets
lol try telling Knox TMU they can't defect you in a shopping centre or carpark, they'll just send you an EPA in the mail.
Yeh you can get EPA'd anywhere, air isnt private property lol
I'd've have fought it. Especially the monash one. It's definitely private property.
But I'm not ENTIRELY sure about shoppig centers. I'm 100% sure with carpark buildings and mickey d's n shit, back in my adolescent days cop told me he couldn't defect my supra in mcdonalds carpark for this reason, so gave me a fine for parking in a disabled zone lol
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
