They don't do Nitto. There was another site that did, can't remember the name right now.
I called tyrepower hawthorn to find out prices of 245/255 17s, they want $350 minimum for anything decent (ad08, rsr or star spec)
Tire Rack has Z1 SS for $186 each. So $744 total, last time I paid $235 IIRC for shipping for a set of 15s. I suppose 17s might be $300 or so? $40 to $60 to fit the tyres and alignment between $40-$100
At MOST that'd be $1200, MINIMUM $350 would get you into the $1400-$1500 mark pretty quick
Ladies and Gentlemen,
Big 80's/90's group A fan here. Bought a R32 Gtr finally and love it, actually daily driving it (won't show it yet till it has got it's new shoes on - totally 80's (3 spoke advans) at the mo and I want 90's! (BBS RS)).
See you all are having a lot of trouble with meets/greets and cops. Sad to see. Just saying hi as I am sure a lot of meets will go undergound and hoping to come/be invited to some.
Tommorrow my Dad (with a Focus RS) are going for a blast up Healseville way and then cleaning at Eltham wash at about 9:30am - 10am.
Cheers, Lincoln.
Welcome Lincoln, put the picture with the tri-spoke Advans up anyway (I like Advan Tri-spoke rims).
Join the club, their meets are usually well organised with zero cops (from when I've attended), not exactly underground stuff and we're friendly bunch.
/Flame suit on/
I lugged a set of these in checked baggage from Gemany... However was a little optomistic with the 2.5 in lips (they fit the back!!!!!!) however waiting for 1.5 in lips to arrive for the fronts (it's a V-spec so 40mm hub to caliper clearance).
Ta for the welcome.
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
