i dont think ill ever get another 200sx lol unless i got into the whole drifing scene..
i dont know how to drift, and wasn't going to try..
theoretically i was building the car for the wrong thing. shouldve bought the evo back when i bought the 200.. the amount ive put into this, if I had put it into an evo.. I wouldve had a good evo.
:laugh:
Sorry man but it's true! Serious! I think about my GTR all the time but i know I will have another, so i just focus on that (well, try to)
I know the feeling :( 3 GTR's and I still want more, I do have problems...
I'm sorry Aaron but I gotta agree, as much as I love my new car the feeling of the GTR through the corners sliding around Winton.. wowee!
That being said I'm still glad I got my car beats it for a daily by far, just wish I could have both! FPV mon-fri and GTR for weekends! :P
Depends are you wanting a more daily friendly car?
I remember in late 06' I was stoked to get a skyline, it was auto and n/a but I couldn't believe I had one.. cost me 8.5k for a 93'!
Quite interesting to see this on Herald Sun website. This is the new strategy:
"Under laws passed in Parliament this month drivers will fork out about $500 to attend shame school if they are caught driving more than 45km/h over the limit, doing burnouts or drag racing."
Maybe it's a gtr thing (here's to hoping) that you guys miss. All though mine is much lighter I'm hoping there's not much else too miss. One thing I will miss though is that horn. Fk yeah.
Still, I'm counting the chickens before they hatch - I still have to sell it.
One thing I dont miss is the cop attention.
Touch wood I never had any - but I still have that sick feeling of "what if I get pulled over - and defected"
I want to get into something Im not so scared to drive
The horn? Really? :rofl:
But yeah maybe it is a GT-R thing, it's the feeling of having your guts thrown back on a solid hookup with the 4WD launch that really gets me
shameless kents, those housemates of mine..
32 cans of coke finished in 3 weeks, how does that shit happen? i've had 4 cans out of that 32. I'll be cracking the shits tonight.
nobody's touching boost bars anymore though LOL
Edited by xALmoN
Yeh the horn. It's a 2 tone air horn. 140db measured 5 meters away. Fkn things made me deaf a few times..
See I want traction man, I don't have it until (sometimes) third and fourth, by then I'm going to fast to even use it on the street, let alone be able to put the first few gears down on a track
PEBSWAC
Put your share of coke cans in your room brah so it doesn't happen again.
Or just become a soup nazi and say 'No Wagyu for you!'
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
