Is that the going rate for rolled guards these days?
Oh my.
yeh. not really lol generally everyone has or is able to do something i am interested in hence the negotiated repayment scheme.
I was being generous
yeh, to yourself.
Aaron said you couldn't do mine could ya?
i can, but your guard dont really have a lip to roll lol - ill double check at alvins next - your coming right?
pffft. he f**ken hit something. it wasnt stretch. nor did sw have anything to do with it.
i seemed to have hit a soft spot.
Maybe, and FYI we don't smash poles, we lift peoples small cars and move them lol
Surely tyre sizes that aren't reccomended for the wheel size will have some sort of percentage to do with it. Side walls like concrete are not safe. Seriously moh, just admit it.
its perfectly safe. my mate drifts his 260kw s13 with 11s on the back wrapped in 235s no problems, never had a debead.
I think you've missed the point of difference from having, to not having traction. But thanks
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
