Cheers!
But wouldn't it bulge out too much?
Shouldn't too much. Dad has 245 on his ford, that's a bIt much lol
I drive a golf, you opinion is invalid for traction...... 205/40s it is then :P
Conformist lol
Out of stock! Just ordered 3 packs from US eBay on your recommendation. ~$25 delivered lol. Still pretty cheap if it does what it claims it does. Lots of people saying good things about it on the Internet.
Oh I didn't buy it through there, my colleague ordered off eBay. They definitely work. Wait half an hour after taking one, lie down in a completely dark room and you'll fall asleep pretty quickly and stay asleep. I was pretty sensitive to the 3mg dose at first and it made me feel hungover the next day but my body got pretty used to it and I'll wake up feeling awesome and refreshed. You might need to adjust your dose once you work out what your body needs. I probably take them once or twice a week when I know I'm going to have sleeping problems. It's a hormone your body naturally produces and it's shown to have a lot of positive health benefits, so in moderation it can't be bad for you. You can't buy them in Australia without a prescription, in the US you can buy them from the supermarket. No issues importing them though.
For the nights I cannot sleep at all Stilnox is the only answer, and it knocks me out cold. But I'll only take it as an absolute last resort.
Edited by llama_au
Yeah it sucks balls. Mine was hitting a ripple strip side-on and getting airborne. Expensive day - two tyres came off the rims (but thankfully were salvageable), scratched the rims up a little, stuffed a rear hub and put cracks in the front lip. The solenoids in the transmission also packed up shortly after. Think it ended up costing my about $1200 in repairs *sigh*
polished existing Slant lips. 17x9+20 all round with 225s
might run 15mm bolt ons all round
I would hope so, I'll be running 17x9 +22 on the golf rear :P
BBS club represent! Might also need some slight gaurd rolling although wheels are the same offset as already on and they don't rub at the mo. However need to mod exhaust to run a little lower so will have to look again. Tracking new lips and outers/bolts from Germany at the moment.
Quite oh my!
Is that the going rate for rolled guards these days?
Oh my.
Careful how much you order, customs usually take an interest as it requires a prescription in Aus
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
