so i sent my phone into samsung for it to be fixed... too many probs.
telstra offered me a new one, and I asked if i can have an iphone 4 instead.
They said they couldn't do a direct swap, but they did cancel my contract and waived all handset repayments so i can have my samsung back (still works, just not 100%) and go on any new plan of my choice with a new handset
pretty happy with that!
iPhone 4 sucks, same shit as using iPhone 3s, possibly even slower.
although it's probably cliched I will be doing that..but they prob just called sir fried noodles!
find out if you can drive on the f1 track? Ill be in singapore for 24hrs and want to also know what can be done haha
weekend in Singapore kgo what do I need to do?
never left airport b4
EAT!
places that you have to go to:
1) old airport rd Hawker centre (take the MRT to Dakota station and it's a 200m walk)
just look for the places with long lines and que up.
Every place i went to there (i at at probably 15 of the stalls) I just said "gimmie your best dish, i eat everything"
2) Tiong Bahru Hawker Centre (take the MRT to Tiong Bahru station)
same deal as Old Airport Rd but close to chinatown. not as big, but most definately worth it -especially for the tiong bahru chicken rice
3) Chin Chn Eating House (19 Purvis Street - less than a block away from Raffles)
you MUST have the chicken rice and the Tom Yum here. best I have ever had. Before I ate here i thought chicken rice was pretty ordinary, but chin chin will make you understand why its the national dish
4) Haji Lane and arab st
- great middle eastern food and shisha
5) fish head curry
eat this in one of the hawker centres- it's the other national dish.
6) tiger beer
drink this
7) Orchard Rd
bring your wallet lol
anywhere you go just watch an Anthony Bourdain and copy where he goes... you can NOT go wrong
http://www.youtube.com/watch?v=5ShPNvhm8VU
http://www.youtube.com/watch?v=IKpEO5Gr2dM
also should read his book "kitchen confidential" fkn GREAT book
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
