anywhere you go just watch an Anthony Bourdain and copy where he goes... you can NOT go wrong
also should read his book "kitchen confidential" fkn GREAT book
yeah just recently been watching his shows.
and on the opposite end of the scale man v food.
Lol i'd love to know what for
Serious.....
I guess you didnt see the picture of the hot girl bent over the stairs with only a pair of stockings on and a buttplug that looked like a horses tail...
It was totally worth it :yes:
Serious.....
Lol if he posted that why is he wondering why he got banned.
yeah yeah i know everybody's seen it and it's an epic repost but still... FUAAAAAAAARK THAT
Sparkies brah
I'm gonna be in Epping tomorrow, have 30 minute lunch break....Suggestions on things that I must do in Epping?
Please respond.
One of Melbourne's many shopping centres, Epping Plaza, is located 500m away from the Epping railway station. The Northern Hospitaladjoins it. Dalton Village is a small shopping centre which is located on Dalton Road in Epping. There are many parks and reserves located throughout the suburb.
epping has a brand new train station could check that out..or just up the road is the all new melbounre market...pretty big deal but not open to public yet...
other than that epping sux ....
Birds demise
http://www.skylinesaustralia.com/forums/topic/409240-wtf-plug/
basically adz banned him for posting porn again....
Keep in mind I need 5 minutes to get off site and 5 minutes to get back on, so 20 minutes sight seeing time
Birds demise
http://www.skylinesa...09240-wtf-plug/
I work at the market relocation lol
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
