Tried going in a servo with helmet on coz cbf taking gear off just for few seconds, soon as door opens kunt out of nowhere yells out "stop right there remove your helmet please!"
Thought I was gonna get shot down..
Chill brah
Wear a burqa, that's fine
He was more scared when you took the helmet off, wasn't he?
yes Riq
you weren't aware.... of something that has stickered on the window of every bank and most service stations in austraila for the last 30+ years?
i haven't been around for 30+ years. sorry
yeah it's f**ked
thats problem i have =/
Shieeeeeeeeeet that's not good...
http://www.metalspinnersaust.com.au/metal-spun-wheels.html
Take it to that joint, and see what they say. They could probably remove the clear for you, polish, re clear. Or they'll just make you another lip. Lol.
Not sure on price. Give em a call.
Chill brah
only because you're a unit, they still let me in the shop with helmet on :(
http://www.metalspin...pun-wheels.html
Better off going to an independent metal polishers and just have them polished (cheaper usually)
Has a better shine because the clear will hold back some of it, and there is always a chance to have it peel again
sweet thank you man, was looking for that site earlier and couldn't remember what they were called!
yeah ill have to have a look around - i know there is one guy who told me he does complete restoration for 400$ per wheel.. so if i cant find cheaper i can always keep that in mind..
Id prefer the clear on it to be honest, i think its too shiny without it on those wheels imo
lol probably been robbed by a helmeted dude before...
Just peel it all off and re-clear coat it?
good tattoo
thinking of getting a tatt on same area. working on a "design"
lol id swap for that!
my old man has a detomaso pantera gts but he lives in syd.. i live in melb, see it like once every 5 years as he keeps it in storage
he got it for just over 10K in the early 80s and it had water in the diff and transmission..
Edited by bluejeans
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
