lol nick looking forward to this one :P
a question to all you guys.. 19s or 20s? keeping in mind my car comes with 19s so 20s don't really look that big
I told you earlier 20s and call WORM.
Job done.
This may help you in the RS measuring
The above pic is classified as a 8" wide wheel. Comprising of a 7" barrel and a 0.5in lip.
Haha yeah had all that worked out, but our calculations for new lips were wrong.
We were .5" to wide in lip selection which is to late now.
But if you want to sell the 6.5" barrels ( from 7.5" wheel I presume?) Then I'll buy them off you.
Otherwise I 'make' these fit lol
I'll make em fit!
ok so suggestions for head phones
must be over ear
noise canceling.
and I'm running pxc 450 sennheiser ATM, so better than they.
go
Sennheiser HD25's
because 90's DJ
(dont get these now,,, they stopped making them in germany and they aren't that great anymore... FWIW my old german ones I bought in 96 are still going strong after 2000+ gigs in the hottest, sweatiest loudest warehouses/clubs there are. I also use them on the train daily and whilst skiing)
Lol your kidding right? Maybe with some camber and a f**k load of stretch lol
they'll fit easy... the fronts on my ksev were roughly twice as far out as those adn we got them in with minimal stretch.
(however they did have super rediculous camber, massive castor, huge flare and the wheel arches extended by 6" at the front so they could clear the door when turning :P )
That'll fit easly. Stretch and camber.
this
Eh? Won't the lips stick out just as far? Unless you're running spacers that you'll be removing?
What he said.
WIll sell the 2 x 6.5in 34 hole barrels (brand new but powdercoated dark charcoal) - for $400.
Washed car - shopping and then did the Eltham - DIamond Creek - Kangaroo Ground loop - awewsome day for driving. Going again!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
