You got some balls Ashrey
I've seen many small businesses come and go
Hope you run the business well as with the new DPN provisions you can still get royally screwed even if your a company entity.
Well at least with all the equipment you'll be purchasing you'll be able to make good use of the new depreciation laws :thumbsup:
Not so much balls, just good homework and business financials that we pulled apart (i'm in with 3 mates).
One of those happens to be a really good accountant ;)
So ye, all covered on that side, he is doing the books lol
Not sure how discounts and what not are going to work as such, I've got a big 8 weeks coming up to get it all sorted (it's a bare shell at the moment).
Rest assured though any SAU guys that come down and bring friends etc, I'll be sure you look after everyone - and we'll have the best steaks in the east :D
Haha sounds draining yet exciting, man. Nunawading fairly close to me, so if those steaks are as good as you say they'll be... :D.
Edited by kaitoukid
lol my restaurant will be 100+, and I'm front of house.
Going to be fun times ahead, but then I've done it before a while back, should be right!
I had no other waiters/waitresses most of the time, it was just me.
rims ordered, anyone got pics of 245s on 9.5"?
hopefully have them on before SnS
What did you buy?
I've got 235 Federals on a 9.5" rim, they are pretty wide for a 235 so should give you a reasonable idea.
Pics in r33 thread
have you used the tomei one before?.. is it better then a lock bar?
Nope, it'll be my first time, will report when I've got it and have it installed
In theory, it could be better than a lockbar when it comes to a time when you need a RWC. But we'll see...
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
