^^ I would be too busy looking at everything else rather than telling the time..
passers by would think im retarded at the fact it would take me so long to figure out which hand is what, when all im doing is looking at gears lol
whens next hop tot alwin.
+1
Waygu hotpot
Yum Yum
i was just thinking about this the other day, but i was thinking of doing a hainanese chicken rice session, using capons. Never had capons before but they're supposed to be very much more flavourful and tender vs your regular chickens.
Haha yeah I'd do the same.
+1 gears inside the watch. always cool to look at !
there's watches that are possibly even more difficult to read (or perhaps only if you don't know how, such as ones by tokyoflash. which can be interesting/different imo).
that said can't go past a nice analogue, so damned classy.
i've got a tx technoluxury or something that dad got for me when he was in US for some work thing few years back - but i only bust watches out at formal events like balls etc. i really would like to wear them more often - but i always forget / my phone tells me the time so i get by
Edited by kaitoukid
there's watches that are possibly even more difficult to read (or perhaps only if you don't know how, such as ones by tokyoflash which are interesting imo).
lol balls.
haha did you take the monday off too? naice.
i didn't even know tuesday was cup day. i never know thanks to it always being during exam time... barely a day off. unfortunately not working it either... dat public holiday rates <3
Sorry Ric got something else on the 3rd :(
Also agreed if you're a tradie watches would probably get annoying, and agree on phone being better for keeping time but watch is just for dat dere' bling bling
(E.G) iphone will auto update when travelling to different time zones.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
