bank kunce
what's the better option
1. small personal loan (~$5k) for a car (through CBA)
2. refinance or whatever the correct term is, my home loan to get an extra $5k (if that's even possible). My current home loan interest rate is 5.97%
go
Wait a few months and save. Unless you're going to pay the loan of quickly there's no point in paying fees and interest. And if u can pay it off that quickly u may as well just save and not bother with the hassle.
It'll be a little hard to refi the mortgage for an extra 5k
Then I'd probably be applying for a credit card or increasing the limit if u currently have one. Just pay it off when u can and drop the limit. Personal loan will only be a few % cheaper if u can find a low rate card. Paying it off in a couple of months and your done
Will also take more than a week for some banks to get a loan where as a credit card limit increAse would be overnight in most cases
Got a 10k limit on my credit card... But think for cash advances the interest rate is stupid high...Don't know coz I've never used cash advance.
Might be an option considering most personal loans charge a fee if u pay it off within the first 12 months...
Hamish & Andy, insider opinion?
Yeh it will be a difference if you make a purchase of a car from a car yard as such. Then there is no cash advance as its a purchase.
There are heaps of yards that have cars for under 5k with onroads included
Lee cousin's mate is selling a blue r6 same as that one should be able to get it for ~8k maybe even less it's '07 but
Lemme know if you want details
Depends how many KMs on it, prefer 08 and newer due to revised engine but if the price is right.. what else can you tell me about it? bikepoint link ?
Is it that really that much of a hassle to refinance your home loan?
Say difference in interest rate is 6% for a personal loan, @ $5,000
It's only going to cost you about $25p/m
Yeh with justifying what the $5k is for since it most banks will want it to be for the house. Then valuations and all that shit, contract refi fees etc. PITA for just 5k..
Personal loan at 6%? Lol where?
Instead of a cash advance you could always send it to your paypal account then withdraw into your bank account.
Listening to RACV battery service guy talk crap to my mum about there being no difference between Lexus SC400 and Toyota Soarers and how they are both made by TRD...do correct or let ignorance slide?
Do u have redraw or offset account on ya mortgage you could tap? As said not worth refinancing for but then personal loan is higher rates and payout fees etc
Lovin the Audi so far and iphone5 oh how much better it is!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
