That's the front
One of my mates cars, currently for sale too
Thing is awesome in person :)
he got it from JPN front and rear 9 with the mivec head and all.
didn't believe him initially that it was a 7
Shit that's a lot of work to be done to do a mivec conversion, that's a awesome car
Engine I presume was rebuilt too?
graphically the main thing deterring me from a 7 was the lights...
with this new info I might just go a 7 and be happy with 220kw odd
Always a fix for cosmetics brah
7s are great.
though at 20k, i'm not sure its good bang for buck.
If you plan on modding bang for buck they become a lot cheaper than a skyline though
about $2k-$2.5k will net you a stock evo to 230ish kw
That's full exhaust, licp, bigger turbo, remapped, ebc and can probably even budget cams in there if you get the exhaust cheap enough
$5k will get you to 300awkw
EVO 7 with EVO 8 / 9 Spoiler?
Yeh but runs the 9 rear bar so looks good cause it matches :)
EVO 7 with EVO 8 / 9 Spoiler / Rear Bar?
and headlights/fin thingy on the roof..
also skirt CF extensions, different front lip, and diffuser extension on the rear bar.
not much really to get it looking like that.
oh thats awesome.
lol not kaitou.. i meant emts.
Sure, sure
I'm just hoping I can get a clean 8 for 17-18ish Christmas next year.
Lol exactly what I'm hoping for as well (perhaps a bit after Christmas also fine). Not sure how likely this hope is, though :S
Yeah.. initial outlay is high..
And i've been thinking about it since last year. Still thinking.
no idea on rebuild was only running around the 240ish IIRC
dont think the work that huge.
Mate just did a MIVEC conversion on his 8MR not super cheap but cheaper than a lit of other mods
boosted his mid range very nicely
do ittttt :P
well I guess it's more for cost and sourcing parts
you need to rewire the whole mivec wiring into the ecu as well
and the head alone is at least $1500 plus wiring
i seriously have no idea why you sold yours.
I do regret it a lot, however at the time I was sick of imports. As a matter of fact I'm still pretty sick of them
Golf gets attention, but not the bad kind and it sits at about 50mm off the ground and has no exhaust :P
also a lot cheap. but fwd gaaaaaaaaaaaay..
though 18km/L makes up for it.
haha that's through town on freeway i get 23 to 25km/l
depending on road incline etc, but usually hangs around 4-4.5 litres per 100km :P
yeh.. im not expecting the evo to be the greatest, but anything would be better than the silvia and its 250km to a full tank lol
expect around 300-350max around suburbs, the small tank is a killer
also they do drink being so responsive :P
well thats fine from a 40 litre tank.
stagea was a 80 litre tank and i was getting max 290km from e85(granted its ethanol)
hmm
I get around 450 around town 600+ on freeway..
lol 270 kw is a very tempting power figure.
and i never did freeway or long distances..
Good to see it's all interchangeable!
lol @ comparing ethanol with PULP on consumptioin
hence why I put in brackets granted its ethanol.
if it wasnt such a risk to do it with the seven rods, i would be tuning on e85 this weekend.
the servo is a 5-10 minute walk from my house lol
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
