yeh i registered.. some strange requirements, but atleast it means the likes of NS will be there ...
Indeed... I tried twice, but got an error though :/
Although I did put my lisc. number as 000000000. But the error seemed immaterial to that, so I dunno :/
Such as?
Location (City, State), first name (no initials), car make, drivers license number; must make a non-one-line decent introductory post in intro section before rest of forums can be seen.
Those seem to be it from what I can gather so far. On the one hand, I see where they're coming from, and didn't really mind, but driver's license seemed a bit excessive / I was surprised lols.
Edited by kaitoukid
Seriously?
All that for a godamn forum?
the cressida ones are even better man...
those dudes even have a fake forum with topics about pension money etc set up until you are verified as a member
LOL hahaha
yeah then admin has to approve your registration i'm pretty sure I had to wait like a week for my evo oz account..
Yeah had a feeling prob need admin/mod approval for reg... thought they'd be a bit quicker than one week though. But still... dat security.
Seriously?
Mmhm.
Maybe it's great once you're in though hahah.
wow I signed up when they first got started so they have none of that for me..
I personally would not be handing that info out over the web.
DOB drivers lice suburb..great for identity theft, hope their DB is secure
Yeah that's why I wanted to sign up - lurk and just gain more knowledge in general.
Haha like I said earlier, not too fussed about some things, but yeah stuff like license I was a bit iffy :/
If 000000000 too obvious, maybe just make up some random 9 digit number :P
Yeah, I'm getting some other unrelated error as I first thought.
"Error: ! Anonymous hit limit reached for IP Address xxx.xxx.xxx.xxx.
Why not get an API key? It's free, and it'll allow you to perform a larger number of bot-screening lookups each day.
If you aren't the webmaster for this domain, please tell them about this error message."
Tried resetting my IP to no avail.
Ceebs. More procrastinating instead of studying for exams lols.
Pics?
check fb all there
Well they can't hand out defects for phaggotry
LOL
They were probably in disbelief of the shit that they do to their cars
hahaha yeh..
be funny if they did..
hey nick;
why is it that all the dump pipes for evo's are only 2.5" exit.
isnt that a tad small ? how are these people hitting over 250kw with it?
Zage dumps are the biggest separate dumps, some aren't even 2.5"
Custom is the only way to go anything bigger than 2.5, I was running a Zage no problems.
http://www.ebay.com.au/itm/Turbo-Dump-Pipe-Mitsubishi-4G63T-Lancer-EVO-7-9-Outlet-/281016580474?pt=AU_Car_Parts_Accessories&hash=item416de4b97a&_uhb=1#ht_2015wt_1397
These are Zage ones... Buy here for $15 compared to $300 from Meek
You can go a MAP Performance split dump front pipe, but it is an absolute headcase of a fitting, it's hard enough getting the dump off with the rear nut
The link I posted is the best way to go, unless you go custom 3" dump which for the power your chasing is no point
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
