Nah even mine came back. I thought its better like that as everytime u take off/put on wheel nuts it won't leave that scratch mark.
We doing Sunday? Or u gonna wait till next week?
ah yeah fair enough then ill just leave the silver bits
haven't got correct sized rears (wanted 9.5 +30 he sent me 10.5 +35) so hopefully i get the ones i ordered soon for the rear and then i'll let you know if i get any scrubbage
I did however put my small 'sortaflush' sticker on which was intended for nats with these rims / for the lols :( taking far longer than intended to put on lol
just bought these for the hub. rather be safe than sorry:
http://cgi.ebay.com....#ht_1120wt_1155
Yeh good. Lol I had "because too expensive" haha
Hey guys.
Just picked up some BBS RG-R's 18's for new daily rims, and going to use my AVS Model 6's as my track rims for some Semi's...
Where is the best place in the eastern suburbs to get some Federal 595 RS-R's in 2 x 235/45/17 and 2 x 255/40/17 and how much do you think it'll be?
kgo, wasteland contacts, unite!
also try wheel tech in Dandy, looked after me a couple times for rs-r
yeah day was massive, finally found a caltex not on the map with vortex 98 so giving that a try.
nearest Bp is20 min up the freeway.
there was some very very fast times from SAU folk,
richo 2nd Mod RWD
madden 2nd SAWD
ANd 3rd ModAWD behind 2 modded R35
plus I'm happy with my run.
Now just a matter of downing beers to dumb down the brain cells so we can go drag racing tomorrow ;)
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
