Pulled up next to a Ferrari 348 last night. His gf was admiring so a race to the next set of lights seemed like the appropriate thing to do. Even with a noob like me on a 2fiddy the feza had no chance :/
Makes you wonder, what exactly is the point of a 600cc+ bike for road use...
I know 348s aren't the fastest Ferraris around but still
Having said that, I've decided that I'm broke and am looking for an older/cheaper 600. Do like old r6 ~2005 possibly best front end I've seen so far but first mod would have to be a "shorty" exhaust coz them big canons look fkn disgusting on bikes.
/csb/bikes
Little-ish 50km/h road I take every time I go in to work... have had an excel overtake me, casually using the incoming lane (daytime / there's colour lights at the end when heading in that particular direction no matter what lol).
You guys are clearly hoons :P
had some ve malloo with 20s on it try me, smoked that mofo f*kn hard - he mad then get the 'thumbs up, i just got f**ked up..' I always slow down next to them afterwards just to see the look on their face hehe
getting front tyres fitted to rims today, no rears though :(
bahaha i considered it too, but i was in 5th, and too ceebs to prove anything of the like. although one of the few opportunities with my all my killerwasps via na powah XD.
in any case, mismatched wheels, drifter4lyf, m i rite?
I won't be able to do them till next weekend so hopefully they don't scrub lol. I have a christening tomorrow Leigh
Can't actually put them on anyway, because the tyres are fatter and the stock low profiles on the rear = traction control system go crazy
cost 60 dowla to fit 2x tyres to rims? dafaq?
eww.
lol i mek fit fo yu yu gi tertee dorra pe wee
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
