anthony bourdain has said that no matter where he goes in the world, and no matter what he eats, the only people that ever get sick on his crew are the ones that eat at the hotel buffets
All you can eat / buffet = bad idea no matter what the situation
you are just ASKING to get sick - if not food poisining/gastro, at least cold/flu etc
I've been going all my life
Must be immune to it by now :P
Where is this mysterious place you speak of?
What did you order? I don't think it's anything special, just very yank and a guaranteed fill up.
Forked pickups for my rear stand
dezzmann, make it to huxtaburger yet?
Nope. Burger tour stalled after 3 joints... gotta get back on track.
This. I don't trust food in general from an all you can eat place let alone seafood. If the buffet is <$60 a head I won't eat there.
Never been sick from.a buffet... if it's a popular/busy one chances are everything is fresh.
Mate at work told me to hit the conservatory buffet at crown
~$100 all you can eat with steak and seafood etc. Will hit
lol guy gets sent to jail for 120days for calling a judge a c**ksucker
From 2mins onwards
http://youtu.be/goTVyb8qO6s
woah!
IMHO that is pathetic on behalf of the judge, yeah the guy is a know and should have shut up, but a judge that is that far up his own ass and that fragile about being insulted should not be a judge
a judge is supposed to remain objective at all times, and that guy clearly not able to keep his emotions out of a descision
remember in a buffet, it's not just the food/chefs that can make you sick, it's how long shit sits there, and the people that are eating at the buffet.
some guy takes a dump and doesn't wash his hands, touches all the food and BAM.
not to mention you have lazy waitstaff deciding when things need to be returned to the kitchen and sometimes topping things up.
I 100% guarantee they will just put new shit on top of old, leaving rotten food there just waiting to attack someone.
I have worked with 100's of waiters over the years and I can guarantee they don't give a shit about anything to do with the kitchen.
Waitiers care about 3 things... tips, free food and free alcohol
fb informs me ftg and stud road corner is having a wonderful epa/defect station! just in case *awares*
in other news...
loving lying around at home today :D.
Might drive through it for a laugh
http://actionshotcam.../news-and-blog/
$50 from Kmart.... anyone gain to be the guinea pig and try it out???
looks like an ok (cheap) alternative to the gopro white...
ill stick with my Black.. i cannot wait to get it.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
