Ditto. You just said you hated looking for second hand, and you want an Evo. Hence..
If you do find one though, look for rust. Look everywhere for rust. Not only on the rail, but in the wheel arches, and under the plastic bits. About 3 that I looked at were covered in rust, but I didn't find it until I was told where to look.
Look for ayc issues, oil level and lights etc.
Transfer case is a common leak as is the oil sump seal and the rocker cover seal is too..
Standard suspension usually leaks and knocks too.
To see if things have been changed in the engine bay, the original bolts have number 7 on the top.
Things I was told anyway
thanks for that man...
before i buy i'm gonna get a full inspection... probably from techsport or state roads.
I looked at one that was just out of my range that had a techsport inspection and i was impressed
this is why i am thinking of importing... can just give IM the $$$ and not spend my weekends looking at cars as it annoys me.
also, i know i might not save any $$$ or time, but in the end I will only ever have this time with my baby once and it's priceless
need to call aaron and have a better chat about it all
Yeh I had it inspected by two mechanics and sent racv to his house. He was rather pissed that I kept sending him everywhere lmao. But I was buying a car I wanted to make sure I was buying something good.
Speak to Aaron, or even northshore prestige in Sydney. Northshore is f**kig insane for quality, asked a few people to do inspections and they all said no need, the cars are 110% of the time perfect.
Lol, did you dance for them?
no
Rode to work today, no one looked at me
how do you carry your tools? :huh:
Awesome day on the spur, can't ask for better weather.
Few f**khead cars crossing over the lines, but what can you do...
do any of those mirrors work or is it just mine that are useless? always have to turn on the bike to look behind/blind spots might aswell take em off...
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
