Ditto. You just said you hated looking for second hand, and you want an Evo. Hence..
If you do find one though, look for rust. Look everywhere for rust. Not only on the rail, but in the wheel arches, and under the plastic bits. About 3 that I looked at were covered in rust, but I didn't find it until I was told where to look.
Look for ayc issues, oil level and lights etc.
Transfer case is a common leak as is the oil sump seal and the rocker cover seal is too..
Standard suspension usually leaks and knocks too.
To see if things have been changed in the engine bay, the original bolts have number 7 on the top.
Things I was told anyway
thanks for that man...
before i buy i'm gonna get a full inspection... probably from techsport or state roads.
I looked at one that was just out of my range that had a techsport inspection and i was impressed
this is why i am thinking of importing... can just give IM the $$$ and not spend my weekends looking at cars as it annoys me.
also, i know i might not save any $$$ or time, but in the end I will only ever have this time with my baby once and it's priceless
need to call aaron and have a better chat about it all
Yeh I had it inspected by two mechanics and sent racv to his house. He was rather pissed that I kept sending him everywhere lmao. But I was buying a car I wanted to make sure I was buying something good.
Speak to Aaron, or even northshore prestige in Sydney. Northshore is f**kig insane for quality, asked a few people to do inspections and they all said no need, the cars are 110% of the time perfect.
Lol, did you dance for them?
no
Rode to work today, no one looked at me
how do you carry your tools? :huh:
Awesome day on the spur, can't ask for better weather.
Few f**khead cars crossing over the lines, but what can you do...
do any of those mirrors work or is it just mine that are useless? always have to turn on the bike to look behind/blind spots might aswell take em off...
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
