Nah new family business car. But might as well be mine :D
Includes on roads and tint. Slightly cheaper cause purchased through a business. 18 month wait though, what a joke...no wonder people are selling them for 10k more than they paid.
Still a 18 months wait? :(
ok have had the car bak for a week now. must say im happy wit the resultshe looks very good. 1st thing i did was give her a wash and polish (excluding freshly paintd bits). wat u guys think of my efforts?
post-30915-1164720141.jpgpost-30915-1164720112.jpgpost-30915-1164720039.jpgpost-30915-1164719983.jpg
wow. i can't believe i used to be this way. and this was one of the halfway decent posts too
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
