paying for a power run was a great idea... turns out the fuel pump was on it's way out so the owner replaced it with a new walbro 255 and also new iridium plugs! :)
radiator was cracked and rear rotors on their last legs, so we swapped em out today.
chasers even kept the car overnight to fix up the fueling and tune for me for the price of the power run... pretty fkn good for a shop I have never used before (know the guys but not that well)
pretty happy with the purchase
all i need is front and dump pipe, LICP and boost cont and i'll be sitting at ~210awkw
COME AT ME SECOND HAND PARTS!!!
Hope it turns up ok man
Not much consolation but insured?
Insured but after excess not much back
All the upgrades time and effort in the last 3 months far exceed MV
on the brighter side...
deposit paid!
One is lost and another is born! Such is life
Holiday from friday, but not going anywhere so will be fitting hugger, fender eliminator and tinted screen over the break
Exhaust is on, looking and sounding porn but bike remains on stands, naked.
waiting on power commander, then can put it all back together, with new indicators front and rear as well as fender eliminator
my friends car was broken into outside his house. Thief tried to start the car but couldnt due to the mongoose alarm. (alarm was off, so immob was stopping him) However due to no siren the guy took his time trying to steal it. Fed up, the theif left the car (which had te37's in the back seats) & stole a tow-truck from a motel. Came back to my friends house and took his car on the tow-truck.
Tow truck had gps tracking and cops were notified. Cops took chase, tow-truck crashed. Thief jumped out and ran off. Any harder hit, and my friends' car would have fallen off the tow truck....
Well the go pro isn't all that great. It's already frozen 3 times. Locked itself.. And it's not playing back properly on the laptop
Not as unhappy as Toby. But unhappy
On a plus side the USA number plate came
oo i want to see pics tomorrow morning. get on it.
What, that freaking sucks bro :(
Worst :(
deposit paid!
cp5276429575099513830.jpg?height=700&asp
sau team evo slowly growing :D
Hope it turns up man
Alarm/Immob Tony?
Who did the install?
Sorry to hear man :(
Cheers brah
Just an immobiliser.
It being stolen wouldn't have bothered me so much if it was before I started modding up the car.
Not the end of the world as that is what insurance for.
Car has been spotted at Shell Emerald Petrol station. Police getting CCTV footage
Hopefully the dumb cnt paid with his bank card or credit card lol
Hey everyone, i know this is going a few pages back... but regarding coil packs and issues with them; Mine on my R34GTT seem to have started playing up (shaking, mainly noticeable on idle) and car has far less power than normal.
This happened to my previous R34GT and i replaced the whole lot with Yellowjackets, this fixed the problem.
I've ordered some replacements but my main concern is if i'm doing any damage to the car by driving it around before i receive/install the replacements.
Because i know there's a problem i am driving it like a nancy boy as i'm worried i'll screw something up.
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
