For stuff that's never arrived, yes
It arrived, but isn't what it was supposed to be in the sense that it doesn't fit.
The ad said fits 'most' Hondas, but then says 'I use it on my CBR 600RR', which is what I have, yet it's the wrong connection altogether.
They'll refund it no worries, but the item was like $8 (bought 2 so $16), then paid $30 something for express postage.. so they'll only refund me what I paid for the item, and probably want me to pay for the return postage as well, which means it won't be worth it at all.
Was wondering if a paypal dispute or whatever it's called will get me my $50 back
New iPad mini as a head unit.. what you think?
like what Mighty car mods did, except removable..
to me sounds like an awesome idea.
you can use it for maps / banking / music / etc etc while on the go
might look a bit strange but idea behind it is pro imo.
well yeh, i can get an RCA splitter and wire it into an amp - speakers, can get EQ apps all the lap timing apps OBD reader from it too so it seems like the perfect Idea..all my music, movies everything can be accessed, and i can take it out of the car as I please..
plus the radio in there doesnt have a radio for aus, doesnt play mp3, let alone have a USB.. and the mini fits near perfect for the two din.. 7.9"
Why though? Because its an apple? Or the whole idea itself
Not because its apple (I own a ipad / iphone myself) I dunno I just didn't really like the idea itself at first.. just seems a bit ricey when you can buy good headunits already :P but when you think about it could work well
Plus it would need to be a very clean install to pull it off, I didn't think of the GPS / laptime capability though so yeah might be good.. just make sure it's installed legit and not like this:
Edited by UNR33L
http://www.skylinesaustralia.com/forums/topic/413143-ipad-mini-in-car-entertainment
hmm, I think I've had postage refunded - but yeah, they usually make you pay return postage
Yeah a PayPal dispute usually gets you a full refund. You and a seller both get a chance to plead your case and then PayPal make their decision based on the evidence. It could go either way but generally they'll side with the buyer
might call him and see if he has a mold, he's interstate unfortunately..
yeah i think you would prob need to go with one of the android tablets to get a better look tbh
the android tablets look shit. IMO anyway.
lol yeh i dont want to mount it inside the dash, i want to be able to remove it when Im at home or leaving the car parked for long times..
basically sits perfectly directly in front, which means I wont have to cut the dash, and IF i do decide to put a head unit back in, i stil have a dash.
sounds like you found an actual use for an iPad.
lol
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
