whats wrong with it??
from where?
Speakers go crackly intermittently, I've tested it with another amp so it's not the speakers that are stuffed, amp may need some connections soldered or something
Got it from jb
no, he already beats his brother or atleast until mid third gear lol.. lol he has an FP green turbo on the evo, his brother is at 350kw or something and daniels at 223kw i think.. its quite amusing watching daniels car just chase things, its fkn lightning quick. after i drove his evo, its why i bought one
doesnt even need cams, more boost and he will be at around 300kw, i dont know what he's waiting for!
How much boost is he running now?
300kw at at the wheels in an evo is no easy feat.
There were a few around my area with big turbos and 2.4 strokers, cams etc makin around 320ish kw at the wheels.
Only running 19psi witch is very low in the evo world..... Cams, boost should place me in the HIGH!!!! 200kw...... I have all the supporting mods so why the bloody hell not... And I'm getting transfered to a closer store for work aprox 2km away from home so.......MEH
You got narre? Awesome
I'm very farmiliar with the evo world, I know them pretty well, that is low boost you're running. Nah all good man, hope you achieve your goals. I'd love to see the final results, post them up here when you get it all done.
Isn't 17-18PSI stock? (Either this or 15-16?) Or is it different for 6's?
Didn't know you had an FP Green... how is that tur-bro going? (Assuming your car is daily?)
Car sounds fun regardless!
Lol nah when I tell some ppl tht I'm running a low 19psi they almost do backflips "omg my 180 is only running 10psi and I thought I was running high boost" lol lol lol
Haha yeah I know, it can be a shock to some people.
sup motherf**kers.
how many turbros do i need to make 721 kws
has to be 721. not 720 or 722.
If you don't mind lag, use your mother.
If resposne is required, your sister and milk her a lot...
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
