Purchasing a VL calais goes a long way towards achieving this
Edit: in4 2013
i have no idea why you have such a hardon for VL's man....
they were cool in like 1989
So were Kool Moe Dee, Beastie Boys and De La Soul...doesn't mean you shouldn't listen to em today.
But I do agree VLs are ordinary. And I don't know where I'm going with this.
De la soul was awesome
Why are the people who tend to make the most mess at parties also the people who aren't around to clean up the next morning/arvo? Inconsiderate pricks in general or mothered too much?
both probably
Ended up going to the hat and getting kicked out along with a mate not long after 12 ah well
Was full of old faggots, apparently the bouncers had 'complaints' prob just mad we were dancing with their milfs
Edited by UNR33L
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
