Anyone able to fill me in on what pod filters you can buy from Supercheap & Autobarn? FRsport has like $60 postage :( and i dont want multiple items.
Usually Drift, K&N, and some can get in other brands I believe such as HKS but it'd be on order.
Nobody wants it :(, should probably just throw it out.
Have this one its way to me which I think is a K&N filter, only bought it for the Tomei adapter thoughdon't want filter & s15 afm.
http://page11.auctions.yahoo.co.jp/jp/auction/n118325010
Did some research, seems everyone is referencing Autosalon comparison of filters in regards to 3A. Found some scans of it if you want to have a read.
http://www.aussiemagna.com/forums/showthread.php?t=73847
Yeh I would go too stupid hamish but agree if I got wheels they'd have to have an oem look with better good offset and not crazy low like the 33 was more a clean look seen a few look ok
Like this guys rolling shots look baller
http://www.audizine....ld-Thread/page3
Cmon Alex
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
