The frustration of wiring up the whole car and amp and finishing everything only to find after plugging in the iPad mini, that apple decided to ditch the RCA and analog outputs hence the smaller "lighning" cable.
Now I need to use the 3.5mm headphone jack to signal the amp
Anger is getting the best of me right now
LOL!
Hey Aaron, saw your orange S14 up the road from me.
4WD spec up front now.
Is the owner curry too?
Nah he's Egyptian I think.. Or something or the sort.
Yeh he hasn't lowered it since I lifted it for roadworthy
I see, I see...
Cause he parked in front of the house where the curries are...
But the house opposite, new people have moved in and one of their custom plates on their cars say EGYPTO (or something like that)
Well that explains it LOL!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
