I snapped another photo of that retarded looking 33...much worse from this angle...
rofl thats awful!
thing on door reminds me of those flying sentinal things from the matrix.. just more shit
taken directly from vicpol website:
Important Links
  • Hoon Hotline
You can 'dob in a hoon' by phoning the Crime Stoppers Hoon Hotline on 1800 333 000 or reporting it online. Information collected through the hotline enables Victoria Police to gather intelligence to target repeat hoon offenders or focus on particular areas.
If you believe a person, or vehicle, is behaving in a suspicious manner write down the details. If you record the details straight away the more accurate they are likely to be, and the more helpful the information will be to Police. Vehicle details such as the registration, make, model and color, or a description of the individual you observed such as age, height, hair color, build, facial hair and clothing.
Can you identify a person, or vehicle, you observed near the area where a bushfire occurred, or do you know of someone who has been lighting fires?
If so, you can confidentially call Crime Stoppers on 1800 333 000 or report it online.
HOONS... MORE DANGEROUS THAN BUSHFIRES!!!!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
