And make sure you update it before using it, otherwise it locks and its a pain to reset
I updated after using it and playing around with it... no problems. :rolleyes:
Ted's is expensive... might go to JB HiFi.
Btw, are you using the suction mount to mount it on the gokart or do you have the handle bars mount?
I have a suction mount, currently it's stuck to my bedroom door and I'm using it as a towel hook hahahaha
then 'accidentally' leave the go-pro on, when the missus comes over...
... i c what u did thar aaron
Let me know how much u find the handle bar one for.
Saw it for like 20-30 but not all stores have them, every store has limited of different stock.
Went to 2 JB and 2 HN, none of them have the suction mount..... looked on the system and only HN in Frankston has the suction mount in stock... was looking forward to playing with gopro. :verymad:
oh well, I'll just do some selfies.
I'm not too far from franga maybe I can pick one up for you?
far out
my dad got a panasonic blu ray player and pvr in one
on the box it has plays divx/mkv and records tv
MY f**kING ASS IT DOES
this product is the biggest piece of shit i have ever seen
shitter than the pioneer vsx-527-k
this thing
wont play xvids which is basically the standard these days and the same for mkv as it;s just a container
so essentially out of about 25 movies i copied for him, it only plays 4 that happen to be mp4 mpeg4 format
and it has to be via DLNA so it expects the pc to do the transcoding on the fly
so basically you hit play wait a good minute or two for the transcoding to buffer enough then it plays
WHAT ASS
the WD TD LIVE is absolute god compared to this device
oh and it gets worse
it has USB on the front so if you plug in your own USB drive it has to "register" it and format as linux ext2
so then you cant just copy your own movies to it and play movies off that, played divx movies must be off the network via DLNA
why design it like that
ASS
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
