yeah it doesnt worry me cos its my dads
he loves recording free to air stuff so he can put up with the ass features =)
ive got two wd tv live's in our house
bulletproof and plays every movie
ive even got two cisco switches now so its a pretty good setup
14 active ip's in my house =)
About to watch The Hobbit...
Watching at Doncaster shopping town... A note to any low brahs... Go up straight to multilevel. f**k the area outside the cinemas. Speed bump + humps are like freaking spikes in NFS, dat scraping :(
Wait till you go down the exit ramp bro. Scrapes like a mofarkin hustler.
Always get scared of the ramps in the Kings Way carpark at crown...never scraped once though. Deceiving.
Wilson's Parking on the other hand...owe me about 5 or 6 front bars.
Yeah, it's bad up there. Hadn't scraped on any of cars I now have and had.
Good thing I don't have to park all the way up all the time since xmas is over - easier to get parking closer to work.
I'm not too far from franga maybe I can pick one up for you?
Let me call them directly tomorrow and check if they have it, then I'll collect it from you at go karts. :thumbsup: That reminds me, i need to pay for that!
So.
I'm going to be having an informal(perhaps) interview at a HR company for my internship, ceo said "lets have coffee"
and i'm going in full formal, is that a right decision? tie blazer and all dat.
Intern at HR company hide all peircings and that butterfly tattoo.
but in reality your going for a job at a i'm assuming professional company, you should suit up as ther a good chance that what you will be wearing on a daily basis.
So. I'm going to be having an informal(perhaps) interview at a HR company for my internship, ceo said "lets have coffee" and i'm going in full formal, is that a right decision? tie blazer and all dat.
http://youtu.be/6Dtn4kP7lrA
So.
Is it a city job?
Suit up bro
Like Martin said likely you'll be wearing that everyday
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
