So she's even less attractive than she is in that photo?
Liking the rims on that 380
Yeah that was a geek challenge to dress them up n shit I think
She is attractive in real life, ran into her randomly /stalker
Edited by UNR33L
oh okay, been hearing people say that the petrol will go stale and lose ron.
Cheers Martin.
it will but not in 2 weeks.
think of how many people go 2 weeks between refills
I've got a older 97 Falcon v8 on a mates property
put battery in it after 12 months still ran, that fuel is maybe 2 years old
wouldn't put that in my track car but still runs.
So by the petrol going stale, are we talking a duration of months?
Well the weather is like in the higher 20's reaching to mid 30's from now till next week.... low 20's is perfect imo.
If you've got a hard set tune which really doesn't allow for any leeway with the ron of your fuel, then wouldn't be loading up the engine if its been off the road for a few months. But driving it down to the servo to get some fresh fuel into it will be fine.
Don't be letting it sit with a full tank of petrol for months and months though, since if a track day comes along and you've got a full tank of old fuel, you're going to gave a bad time unless your drain it out.
Also, I wouldn't be trusting Stale Fuel + Octane booster... Really not the same thing as fresh fuel ;)
What advantage is having a iPad mini instead of a regular headunit?
Don't you just use it to play music?
It's not like your going to browse or watch videos whilst driving?
Maybe using GPS & Maps?
Maps
Evo scan(tuning/diagnostics)
Go pro controller
Lap timing
Internet if I really needed it
And something different
I just emailed carbon34 about the custom dash which he's making for me. Should sit flush!
grats on getting it done man
i saw this one the otherday -
I like how behind they have the normal sony headunit still
Yeh heaps of cars have dash's that are available off the shelf, but I'm struggling to find anyone that has actually done it to an Evo 7/8/9..
Lol I like to think I'm first
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
