Wanting to get a stagea now??? :yes:
Got it imported from a private broker/whole saler. His name is Phil from Darby Auto.
He mainly does stageas, legnums, a bit of caldinas and other imports.
Can pass on contacts if you want, don't bother with the site if you look it up though...
Nah no Stagea
Was just curious :)
I'm likely to use Aaron from Import Monster if I do import
Not on Apprentice wages I won't be getting an 8 though :P we'll see anyway, I could wait...
Yeah you're right, we'll see how it goes anyway, won't be for 6+ months, but you guys aren't making my Wants/Needs ratio any better :P post moar pics in POST YOUR RIDE!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
