he would have man... but i am unaware
if you search "lams" on evolutionoz.net you will find a 10 page thread on it
cbf, need a full RWC just to view that forum.
Might peruse Carsales.
4 doors, newer, more comfortable. But unsure about comfort factor...was riding in Aaron's the other day and I rate my Skyline for better comfort. I do like the cushy lounge style seats of the 90s.
The front would be comfortable for your skinny ass
To be honest I find it pretty comfortable, but I'm coming from a small car extremely hard to get out of
2lt is not a problem at all birds...
given the gearing and diff ratio, my evo has basically the same amount of lag and almost the same length powerband my 33 had
feel free to drive it any time
You forgot to mention half the power lol
yeah, there's that too :/
i'd say that given drive ratio's and diff... evo's need slightly less power to be quicker in the lower gears..
i'd estimate evo 200 feels about the same as gtst 230...
not to mention that in the wet i have 700 times the power now lol
And if you're driving it on the street, lower gears is where its at... Who gives a flap how it pulls in 4th/5th/6th if you're not on the track...
exactly... but the way the 33 pulled from 150kph + I AM GOING TO MISS
I beg to differ, I wAs keeping up fine with the 240kw plus cars down the straight at sandown. It's a very under estimated car
Given above 150kph, is when they start to pull away
Even gave Scott a run for is money in the 350kw Stagea. He only pulled away at 120kph.
Hence why he bought one lol
I want to see this first hand. Not saying I don't believe you
Tonight
Your car vs say Simon/Birds
Roll on from say 70km/h. That's about the exit speed at Sandown onto the coming straight
from what aaron has said about this sandown trackday i'm beginning to think that semma didn't die that fateful day... he just got badly burned and decided to go into hiding as a srilankan collections worker
What? Who's semma
Tonight
Can be arranged. Although I have it on video with the go pro lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
