thanks tony i might do. i just dont like heading past dandenong and what not cos of the popo!
well its an auto.... full 3inch kakimoto with (ahem) hiflow cat. rb20 actuator 34 smic, safcii (not tuned yet) sitc(not installed yet)
have a metal intake and pod filter etc, but soon going front mount so im converting to a scotty metal intake and back to airbox.
it goes alright for an stock auto... spent most of my time on the look of the car tho. once that was right then its time to go to stage 2 on the engine.
got a gtr fuel pump ready to drop in too. just want some cheap s15 injectors and then of to trent at chequred for a tune. anything over 200kw will make me mucho happy.
maybe before that ill get stage 2 shift kit.
U don't have to drive brah! I'll pick you up or meet at my place! Make the next meeting! Will be good and change your opinion ov Vic. As I said, it's just half the people in this thread hate the world
Lol shuttup.
Nah he tried literally driving into me where there was no room. So I told him to have some
Patience, then tried telling me that one lane is too lanes, so I told him in Australia one lane is one lane, not like India where one is two. And he goes "you are f**king idiot" in his accent so I started immitating him
Hahaha. The funny thing is western onlookers thinking two Indian guys are bagging each other about being Indian, not realising the diff between you two :P
Refer to my sig lol
How soon do you need injectors?
let me know when the next on is and i might come along bro.... be good to put names to faces.
Refer to my sig lol
no idea what this means.... but no rush for em bloke. 240 on standards or there abouts? well i cant go above 200 before shift kit or box goes bye bye...
Standard injectors should be good for 220-230rwkw
Same with the AFM
So yeah if your stuck with money stick to under that
Same with the AFM
not a stuck thingo, but just taking my time with it... just working down the list of things that are restricting me..
cheers for the advice too! :yes:
Lol that's what I kep thinking. I enjoyed it.
Would you want an ss2 turbo? I have thought about selling it....
Only got used for a dyno tune, 3 weeks on the street, before some guy stole it and blew up my engine
I've checked the turbo stil pretty much new
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
