Jet Skis are sick and wet suits were invented for a reason.
+1 on living at home until you actually need to move out. Living with a single parent is much easier / more independant feeling than both parents, though.
+1 on living at home until you actually need to move out. Living with a single parent is much easier / more independant feeling than both, though.
Jetski's are awesome, but stressful when youre hiring someone else's lol
I'm guessing if you rode it quick enough my bike would see 150-160 on some of the straights.
Yeh I reckon bout 150, more if you really wanted to push and brake late
Stuck to the 235km/h speed limit riding home tonight...
Good night out with a 600 gixxer, R1 and 1100 doocarti monster
crazy
slow down motherf**kers
dude on a white blade (current shape) kept nodding at me as he turned past not sure if he was mirin shiney hilux or just letting me know that he was aware of me droolin over the bike.
do want.
crazy
do want.
When you get your white blade you'll understand...
I'll still give it 8 months and I reckon I'll be back on a motard.. :D can't beat doing jumps and shit over big speed bumps lol
easier / safer to do wheelies on too
Edited by UNR33L
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
