I already have a protege during my own training sessions...so unless you wanna pay me to train you on the regular outside of that, all I can do is show you the ropes once or twice and send you off on your own. As you're an unemployed mechanical engineering graduate...I won't need the cash.
:yes:
I wouldn't mind taking the offer but I'm from the west so screw driving to the east for gym!
I seem to always progress but i just need to be consistent, last year i would gym for a couple months then take a couple months off.Just getting back into the routine a week or so ago after having like 3months+ off gym. :wacko:
How long did it take for you to train Leigh up to now? I'm jelly lol
:yes:
Leigh was training for a bit by himself, but didn't start making serious gains til he joined my gym. Been training with me since November. Back then he had a 70kg bench. If you like I can send you the program we do, it's a two day split with 4 gym visits per week. All you really need to do is lift, eat and sleep...lots of all three.
I thought it was the...knowing people who know how to get rid of a body...thing.
I thought it was a combination of that + his general douchebag attitude and that his car is just so awesome and fast and everyone elses is just a shit box.
I remember the very first SAU cruise I went on organised by Harsh and all Kris was doing was bagging out Harsh in front of 10+ people, non stop.
:yes:
yeah as Birds said, did a about 2 months 'home gym' before I joined a real gym in November last year which is when the gains really started.
I'm pretty dedicated now, after receiving some compliments from the ladies it just boosts motivation even more lets be real. The strength gains are a bonus, no need to trolly stuff around at work anymore!
I already have a protege during my own training sessions...so unless you wanna pay me to train you on the regular outside of that, all I can do is show you the ropes once or twice and send you off on your own. As you're a mechanical engineering graduate...I'd need the cash up front.
All this gym talk making me feel lazy.
Do you accept chocolate as a form of payment?
I woulda given it back ten times as hard to that vertically challenged piece of dried shit
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
