Fuck yeah!
Anti-Lag system is epic!
You should Anti-Lag your EVO!
will do when i tune it for the bigger turbo... but it's not sometihg you use often unless you have a specific desire to break shit
:laugh:
Just take it easy and launch only when needed to.
they disturbed a LOT of people last night
was meant to be a c130 doing a fly over on stkilda beach releasing angel flares:
pic related : c130 releasing angel flares
however at the absoulte last miute they post someting on their facebook page saying that there has been a technical difficulty with the plane and that anoter c130 could not be organised, but if you wanted to see it then just go to the airshow.
what do we have like 1 c130 in vic and that's it?
IMHO it was a stunt designed to get people to pay to go to the airshow and was never going to happen.
I'd bet they never even got the appropriate permission to deploy the flares
actually we have none in vic
24 based out of NSW but many deployed supporting our troops and some shut down as we selling them to indo.
woohoo for wiki
if i had the choice between cars and planes it would be planes for sure
i'd buy me one of these bad boys in a heartbeat
unfortunately I don't have $2 mil odd to spend on my hobby :/
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
