Just ale one of her old rings. She'll just think she lost it
problem is she doesn't wear much jewelry
Cant u just buy and re-do size later on if needed?
Yeah it's been suggested to me, but it's kind of extra $$$ for nothing if I can get the size
how to get ring finger size of missus....... cut it off while she sleeps?
So the current "thing" is.
pick the diamond for the ring purchase it, and present that.
then she comes in to get the ring made.
that said ti was not what I did, I went with a el chepo ring for proposal, and explained she could pick out her perfect one afterwards...seems to have worked.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
