if you dont mind me singing off key, lets do it.
i has bad habit, sing to the highest of my vocal range, then drop 1 octave and continue singing, sounds bad mang.
yeh im serious.. organise it. we come. you sing
i can do that if das what you want.
hahah tuts ma burret.
ahh, sao many drunken fun singing times there. bit more local (to SE anyway) ali baba at glenny is okay, past two times i've gone there. mainly just 2ez to get home! also in city is kbox and fm i suppose. take your pick!
usually deals work out okay $ wise; but protip: smuggle some drinks in ;)
How long was/is the trip?
After a while, you'll realise you want to do it again, I know cos I want to do UK/EU again...
Trip is about 4 weeks total. 2 of them in Vietnam
Next trip will probably be South America or a small trip to Tokyo/Hong Kong pending on time and funds
need new fishing combo.
mainly for trawling from a boat witha little bit of peir work.
thoughts?
http://www.raysoutdoors.com.au/online-store/products/Shimano-Scocorro-662-Spin-Combo.aspx?pid=283680&menuFrom=1021858#Cross
fibre rods are heavy. and a 4000 could be too large even for boat.
just went and took a look at my stuff.
I use a berkeley dropshot, from memory i spent about 80ish on the rod, and a daiwa procaster 2000, hasn't let me down so far. problem though, its an 8 footer. i got it primarily so that i can cast those squid jigs further.
I have a g loomis custom rod, a mate gave me for my birthday, its primarily a boat rod, used to be coupled with a daiwa freams kix 3000, dropped that into the sea off indonesia. but that was an indestructable setup. literally dragged fish up. but cant afford such an exy reel now. unfortunately.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
