washed bike and car today, #productive #f**kinghashtag
Just got home from gym and thinking should give car a wash as well!
Its a bit too sunny almost haha, no shade u_u
Edited by kaitoukid
Okay, so this is the first thread i have started since joining the forum as soon as someone told me about the azn chicks thread.
It's not super busy like Skylines australia/boost cruising etc but the posters generally seem more intelligent, friendly and most awesomely the mods don't enforce ridiculously medieval rules regarding sharing of le boobies!
Still, I'm pretty sure i will be going out on a limb with this thread so before i go any further..
WARNING
Emo/Beta content WILL follow.
Now that that's out of the way lets get on with it, you see I am currently single and because of this dire situation have been forced to get on the interwebs to try and meet new ladies.
I signed up with a few of the more popular sites like RSVP, Oasis, Plenty of Fish and even Adult matchmaker for the lulz.
Since then its been a steady flurry of emails, photo exchanges and eventual dates, sometimes the contact would cost money (I dont want to know how many dorrars i have thrown away on 'stamps') but surprisingly a lot of the time it would be free (POF, oasis and person.com) and the only investment was a lot of time when mass emailing teh ladies.
I have met some shockers, some honeys and a whole shed load of absolute completely psycho hosebeast tree jumping swampdonkeys.
Theres been the usual highs and lows basically.
Finally i come to my point..Those lows.
I can usually shrug them off and get back on the wagon knowing that it will just take ONE more date for me to find the ONE.
Surely i can get knocked back or friend zoned AGAIN?!
wrong.
here's two messages i got today, one via facebook and one via text.
the text
" I'm sorry to say this, but I'm not sure if I'll be meeting you again; even though I do enjoy your company and our conversations, I'm not sure you're what I'm looking for.
I'm sorry if I haven't said it before, but I've only thought about it today.
Wish you the best, and good luck!"
like i said, normally, meh, next?
Two in one day though got me a bit rattled..
1. how do you guys cope with rejection?
2. any decent stories re online dating and if so share!
3. i really just want one of these..
what inspired me to finally be an OP
bless the lulz thread.
TL/DR
I keep getting knocked back by bitches and am foreveralone.jpg and a bit drunk.
here for free advice and/or hugs.
thanks guys, yeah Curtis i thought sophie wanted mah cawk.
guess i was smoking a big fat pipe of self delusion again, before this turns into a self pity thread though (too late?) i have another date lined up later in the week. This time a brasilian, this one is going to be into me FO' SURE!
lol, i've had a pet spider before, not the most charming of pets tbh.
and 2kg of seaweed salad, f**kEN AWESOME
I want seaweed salad :(
if there was pho involved, i would go to hallam
Yeah I'd go for pho too
wanna put a bike in upstairs sitting/tv area. waste of money or?
perhaps some good looking 250-600cc auction spec/track only/unregisterable cheapo doesn't even have to run
lee dez birds let me know if you wanna store yours at a safe warm environment for winter ^.^
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
