LOL! Possibly. I'm reading about the Flex Fuel system. I think I might do it.
Honestly, I can't find a good reason you wouldn't do it.
Plug in Haltech with the Haltech e-content sensor.
Also allows you to pimp out the dash with with a racepak or something if you like :)
do it!
make you feel like your driving an f1 car :P
i just wrote up all the parts ive purchased in the last few weeks getting ready for my.. build? and im sure im forgetting parts or am missing parts i still want/need =/
do it!
Tell us! I just got my full 100k service parts for cheepcheep.
oh nice! yeah you would man! lucky :P
well the list ive got is ...
nismo cluster
nismo brake lines
nismo clutch line
nismo super coppermix twin plate clutch
moonface superlap tie rod ends
moonface superlap tie rods
cusco tension rods
cusco drag rods
cusco front arms
garrett -9s
hks actuators
apexi power fc & hand controller
hks extension kit
hks cam gears
dba 4000 T3 rear rotors
kudos 100k service kit
project mu b spec pads
ID1000's
nismo fuel pump
trust oil filter relocation kit
i think thats all ive purchased.. and i still need to get
rear + front swaybar links
rear d bushes
Edited by bluejeans
fuark, that must of been a big invoice lol
to be honest i dont know how much ive spent exactly.. but its been a few parts every week for a fair few weeks now..
just waiting for some parts from jesse streeter / some from perfectrun / and a few other from random places >,<
but yeah just hanging out to get it all done!
That feel when Santa delivers a package nearly daily...... hnnggg.
You better not be installing all that at Racepace :P It'll be sitting here for a week + with all THAT!
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
