Happy Friday everyone, any plans for the weekend?
I'm going to be replacing my Intake Manifold Gasket on Saturday... going to be so much fun :|
And Sunday going to be finishing off my frankenstein rear end with the freshly rebuilt R230 1.5way and GTR Drive Shafts... but still with GTST rear hubs... (hubs are a little smaller than the gtr ones, so going to have to join the gtst splines to the gtr shafts at the CV Joint, urgh)
Should've get the bloke to throw rear hubs in to make up for 6 weeks of wait to get the rear end.
how about these on the GTR?
*strokes beard* hmm....................
90s TE's with the rounder spokes and flatter faces look the best imo.
What about TE37 Fortessr?
Light wheels, had a set in 19s once and would want another set...
lol true...
also TTA's look like cheap ripoffs
Probably the reason people haven't jumped on it.
They're not TE37s though, they're related but they're not called TE37. Sticker lists them as DAY-TE
http://www.ebay.com.au/itm/181033468359?nma=true&si=Q273Vv4hTS3ILfOaZXni6YvM7NE%3D&rt=nc&_trksid=p4340.l2557&orig_cvip=true#ht_814wt_1397
When I had mine, it said TE37 on the sticker, mine was 19" though.
I'll see yours and raise it with...
TE37 Forged MAG.
Lot of love for egg cartons. Might sus out clark rubber for some proper shit. Easier to acquire than egg cartons without buying 15 dozen eggs
Just ask anyone who works in a restaurant... boxes of eggs have the 6x5 egg cartons and about 10 per box.
there is a car that "rocks" those near my house (it's actually a bob jane company ute)
I get the "pleasure" of seeing them regularly
oh and they tryes also have that red stripe on them
This colour is the baws of te37's, would rep 100%
Yeah much prefer proper te's than the SL's
Lol all the bob jane cars roll with those kinds of wheels, it's a sign to avoid at all costs :P
When are you reppin' these? :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
