Less gap means a less powerful spark, but it is also less affected by higher pressure inside the cylinder. As far as I know. So it might be less powerful but it's the lesser of two evils when you have misfires.
feeling better nao borci?
Not really, she still contacts me every few days, whether it be about something useless like how she saw my cousin at netball, or how thursday night she had a bit of a go at me thinking it was me that logged into her facebook, and how i've f**ked her right off and don't care about her anymore. I gave her nothing back... blunt and honest, tried not to show any feeling.
I'm going out tonight, theres another girl now that I'm NOT interested in in the slightest, but shes becoming attached and it's doing my head in lol. I dunno man, I still have this little hope inside of me that me and the ex will get together again sometime soon in future, and I think it will happen, but I need to let it go.
This was what I was getting at, clearly he has less power with a misfiring car, than with .8mm gaps on his spark plugs.
But now I'm curious with the whole less gap= less power I didn't think it would really make a difference, once the shit combusts it would explode anyway wouldn't it?
Ford forum sponsor has special $2000 for:
FG 6 Piston front kit @ $2000
Brembo 355mm slotted rotors
Brembo 6 piston caliper
Brembo brake pads
Goodridge braided lines
Custom alloy brackets
Tempting! Perhaps then I might do some trackdays..
Thoughts about Brembo rotors? how to they compare to DBA?
Edited by UNR33L
well, try not to lead the other girl on too.
unless she's hot, then, you know, by all means, carry on.
The bigger the spark, the faster the compressed mixture burns = more power...as far as I know. I think it's one of the reasons ethanol makes more power, because it burns faster than petrol?
Ethanol burns slower..
But wouldn't the same amount of current be traveling through the gap? I mean I could understand how a higher voltage would create a bigger spark, but not just stretching the distAnce between the two elements
So smaller spark would then require more energy to equal the spark produced by the larger gap?
more like, the hotter and bigger spark is due to the larger gap, thus larger arc and ionisation of gases.
but i would assume a bigger voltage is needed to be able to form the arc across the gap, thus when coilpacks are worn, or ignition system is bad, bigger gapped plugs would show moar misfire.
On looking it up again, ethanol does burn faster. It's what creates more torque without even touching timing - more heat (not hotter, just more of it) created sooner and therefore spending more time exerting force on the piston than petrol.
If my mind is in the right state, a similar principle applies to advancing ignition timing (be it with petrol or ethanol) to create more torque/power: you're firing the cylinder closer to the start of the "power" stroke, so the heat can push on the piston for longer.
As for spark gap: the bigger the gap, the longer the arc/spark = the more spark there is to ignite mixture = the faster it ignites and burns = the more power it makes. Pretty sure that's how it works. This efficiency is, however, negated when your cylinder can't ignite at all...which is Pat's current (pun) problem. The rule of thumb is that you should run the largest gap that doesn't offer misfires.
Edit: What Alvin said
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
