yeah man pretty good value considering it comes with everything! I'll have a think about it
What's the stock setup at the moment on your Ford?
How do they hold up with the power at the moment?
Weekly wash and a 6 monthly detail from final inspection :P
well worth the effort too...saw your car at dyno day it was clean as a :whistling:
I do clay and wax every 6 months...other than that just wash it whenever..coz too busy washing other peoples cars to do my own..
my skyline looks like balls :laugh:
322mm rotors, not sure about the caliper but pretty sure the SS runs the same.
quote from a review actually:
Braking: With the same brakes as the XR8 (322mm and 302mm discs, sliding calipers), the 315kW GS is under-braked in our view, even as an entry model.
Feel through the pedal is soft, making it poorly matched to the ability of the engine. A shame, then, that the GT's four-piston Brembos are no longer an option on the GS.
I mean they're fine for the street really.. it's probably more if I want to do some track stuff
Bonus is also 6pot brembos look badass :P
But yeah bit of a shame you couldn't get the GS with brembos it does feel like it's missing them.
Edited by UNR33L
you mean weight...
Who is good for mech work? Is sabaddin the only (non-Racepace) club supporter?
GT Hyper, tell 'em hamish sent ya
usually frankston people are only one of those things...
oi!! i heard that kunt...man I cut and polish the crap outta your car twice and nobody even notices a difference..spend half an afternoon on birds car, give it one quick buff and its noticably better ...
I hate white cars....:rant:
Used to pack a spray bottle of waterless wash and clean microfibre cloths, wash weekly, wax monthly, and clay every 6 monthly. After 3 years, it only got washed in the summer and then only if I had a meet or I was going out.
Yeah right!
I mean, you could get away with running a top quality set of front brake pads and slotted rotors with the stock setup.
But if you are finding you need more stopping power, this Brembo kit for $2K seems the best way to go for a street package...
Yet you are also track ready.
you mean weight...
:rofl:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
