Nice, Alvin. I may still check it out then, since it's close by. What is this magical bun bo hue??
Huy, I did mean lolololo. However, I suppose, yolo is also apt. Essay was worth 30%, too, xD.
any good bro? some local pho that's decent might be good in these upcoming winter months!
in other news, me earlier today:
due @ 11:55, submitted @ 11:55 LOLO.
Used to email assignments even when I hadn't completed them...but the attachments would just be shortcuts to the actual documents...such an easy mistake for anyone to make! Usually bought me another day or two until tutor wrote back saying attachments aren't the actual documents, just shortcuts to them.
Also made friends with a security guard so I could hand in physical assignments on campus at 1am.
Also used to get office to date stamp the cover page for an incomplete assignment due on a Friday and hand it in on a Monday if the pigeonhole hadn't been emptied yet. Office started catching onto it so I had to give them a bullshit assignment with cover page and remove the staple / carefully staple it back onto the real assignment when done.
Once stayed up for 36 hours straight, starting and finishing an assignment that should have been started 6 weeks prior. Try doing Z/T tests and quadratics after the 24th hour of working on an assignment :/ Got an HD somehow!
Every extra minute counts when you're a professional procrastinator.
Ahaha, I remember doing similar with ppt and pptx back in highschool, when the school computers still didn't have new office; got a few extensions on presentations that way ;)
Best part was I didn't even have the new office either, LOL.
Lol, not bad on the attachment. We have to upload, but I'm fairly sure I saw a clause that stated no matter the reason you'll get penalised for lateness *shrug*. But maybe it'd depend on tutor, might be some understanding nice people!
LOL@dodgy date stamp ahaha.
36 hours, solid effort brah. Til now, I've always done these essays the night before/all nighter. Today first attempt at on-the-day-during-day-and-night-time. We'll see what happens. Most annoying was not realising I had to reference in MLA... never done that before, only APA (and Harvard) so I spent last 5min trying to change it into something that resembles MLA.... oh well! XD
Good times, now that it's all over :thumbsup:
Well the way I saw it, I was going to get penalised for being late anyway...might as well try on a good excuse.
Ahhh referencing...was always good getting to that part because no more thinking involved, however tedious referencing is. Of course, you could just write down the reference as you use it in your introduction :)
In Psychology we got penalised for marks if our tables had the slightest differentiation from APA standards. Talking...if you added an extra cell or something arbitrary...so shit.
Time saving protip: use an online reference generator :)
Another iPhone protip from the desk of Birds:
Google images not so long ago changed their mobile view to a shitty one that doesn't allow you to full size view an image; only scroll through the thumbnails and view their source websites. This is a pain when you're trying to embed an image on forums because you can't get a direct link to the image from it's full size version.
So...just hold your finger on the image, then tap copy...then paste into the Safari address bar...the text in there is a direct link to the image. Copy this text and then paste in a forum reply box :)
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
