Yes it is. I'll do it, need some moolah :P
I love black carssss
Do mine, but at my house, and for cheap cause I just spent enough money atm :P
Looked like that hurt, although the other guy that caused it seemed fine
So... I'm thinking I had a few drinks tonight.
ended up watching fast and the furious for the first time in many many years.
first off I was surprised just how much I noticed compared to first time, ie crappy parts (mainly sparco) that I would never put on my car.
then I started thinking just how do you end up in the "scene" ie how did you end up getting into jap cars and modifying them, as 10 years ago I was all into US muscle, hell still like it but yeah.
first experience I had with Jap cars, one of the guys I worked with took me out to a MCCR "street race night in his heavy modified MkIV supra.
one thing lead to another and I've spent way too much on playing with cars since...
so what got everyone else into the addiction?
Always kinda had an interest in all sorts of cars as a kid, for some reason Jap cars I remember always drew me in a bit differently, then all that FnF/Hot4's/NFSU(I was what 11-13 gimme a break :P) shit was big and I guess that moulded my thoughts a bit more then it's just grown and grown from around there.
This is why whenever I take people up my mountain run, I drill it into their heads to stick to the left of the road and not take the racing line. Too many cars go half a metre over the line on a tight corner. Sometimes you just can't avoid it though...
Used to be into 4x4's until I was what 11 or 12 when I first saw a car flying past with distinctive taillights - it was a MP 33 GTR. As I grew older with introduction of Autosalon mags and shows, FnF etc, bought first car which was a Patrol with 30ET inside (it hauled real good) thinking I'm still into 4x4's. After I'd sold the Patrol and rest is history.
/csb
I have half of the Street Machine issues ever released...thats over 30 years worth..I think my oldest 1986...
old man had a monaro.. I bought one too but couldn't be f**ked fixing it....I ran into an old friend with a skyline for sale, he let me drive it, i had cash...end story
Wouldn't say I'm addicted...
But I had seen the odd R33 on the road as a kid and always thought they looked cool. Then mates in year 11 properly got me into Jap cars with their talk of Supras and 180s. Then a mate with a Civic on his Ls introduced me to MCCR. Then I saw a 180sx cruising on the road with a CV8 Monaro (they were new at the time) and I was like...I have to have one. Parents said no :(
if your still spending money on a 33...then sorry to say your addicted.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
