Safety gear first fgt
In my defence if you check a few pages ago, already hit up AMX to have a look! Going to try and head into a Peter Stevens / Bike Mart later this week as well for a look-see! Liking Alpinestar jackets... so need to go to peterstevens to try some on :D.
When it's time for bike itself, I may need your mad bike inspection skills if you're free to help, Birds! THANKS IN ADVANCE ho ho ho :D
It is true I am the CBR inspectah
CBR inspektah, thoughts on bikes all the way in Geelong/Bendigo LOL...
Think in the end will just stick with a kwaka 250...
2 mates that just got ninja 300s have those white alpinestar jackets and gloves, they look like power rangers :P
Only makes me want one more... power rangers are awesome? XD
Thinking of getting a predominantly black one though maybe...
Toyota Crown's can now be imported up to 2003. shit yeaaaahh.
http://www.j-spec.com.au/featured/1999-Toyota-Crown_Majesta-16475.html
I saw that...think i would prefer a stag though..thing is damn ugly
Ed actually thats different to the wagon i saw earlier...
Anyone know a bathtub resurfacing contact?
i'm after this aswell as I'm about to get mine done.
TBH I have had only looked at Jim's so far and they want about $700 inc all prep and a new sinkhole thingy
Contacted two small private companies. $600-$700
Guess Jims is on the money
yeah, that was my thought... i'm happy to use jims as they have the name to back it up and my bath was redone years ago so it has 2 coats that need removal and will be a PITA.
also it's so old it's probably lead based paint so fk doing it myself to save $100 lol
To bad they look shit, the 04 and up models look good, if it was until 04 I would be jumping on one straight away
Thats alot of moolah
Just to resurface an old tub.
How much would it cost for a removal of the tub and a put a new one in.
You could do that tiling yourself even
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
