Lol, first psych assignment (worth 15%) had marks released today... And we received a score out of 15.
And I get email updates on some of the questions students post up on subject forums... like...
"because if it's a pure % instead of out of 15 then I've done horrifically badly and will spend 2 weeks crying. So I hope it's out of 15"
WHAT AM I READING? Damn jaffy units. They panic first, and don't read instructions. I need to disable these updates...
WHAT AM I READING? Damn jaffy units. Panic first, read instructions later lol.
aaaaaaand these are the people that will be fixing people's brains...
Now to drive all the way to uni because the assignment I just finished requires hard copy submission, sigh.
Maybe I'll wear some new clothes, got some asos shit today. Deliveries ftw.
yeah, that was my thought... i'm happy to use jims as they have the name to back it up and my bath was redone years ago so it has 2 coats that need removal and will be a PITA. also it's so old it's probably lead based paint so fk doing it myself to save $100 lol
yeah
You still have to hope you get the guy who actually knows what hes doing though, there is alot of dropkicks working there but Jims usually have good back up warranties and that usually to cover their ass
One of said dropkickt resealed our shower....6 months later its all leaking again warranty fixed it and this time we got a guy who knew what he was doing..luckily we hadn't repaired the wall behind it yet which had rotted out previously or we would have been doing that all again too...
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
